A Mark, by default, uses the F/C/B time of the cue that contains the information for the fixture intensity, correct?
So Mark could be described as "use cue time" - to change the mark time you change the cue time- either as a whole or by channel...
But I find myself constantly setting mark time to be zero (or 1 second, or whatever)...
I'd love to be able to set mark to use a default time, rather than cue time...then i'd spend a lot less changing mark times...
you could do a:
[mark][@]<cue>[time]{use cue time}
or
[mark][@]<cue>[time]{use default time}
etc...
Even better, what if i could do a default mark time by fixture type too? so my big heavy VL3500s could mark slowly so the truss doesn't start to swing, but my little mac 101s could mark faster because they're not going to get anything swinging...
Better still, what if i could set a default mark time by parameter, or even fixture type and parameter... so my VL3500s could mark focus slowly, but the color an beam parameters could mark faster...
whatever the variation, i'd spend a lot less time changing mark cue timings...
thank you!
