DL3 v2.0 Control Personality- MSpeed (Focus), does not display in column view in the focus column (or any column).
Thank you!
Thank you!
yea... that's what i thought too, but its silver (displayed) in my CIA, and when i try to toggle it (ion, so data + select with mouse/touch screen in CIA), all i get is a the button toggling in CIA, and not displaying/not displaying in my live table.
pan/tilt other parameters toggle fine.
M speed shows up fine (and toggles correctly) with my VL2500
sorry if there wasn't enough info in the first post.
thank you!
the january 1.9.9 release.
relates to ETC tech case 300215600:
we've had lots of issues including, but not limited to shift/time not displaying the same values between different users; values showing up as "disabled" in about/patch; some other good stuff too.
I read thru the issues that you have called in about. Could you send me your show file? Email is: eos (at) etcconnect (dot) com. Please put Attn: Steven Peterson and reference this forum.
A couple more questions too:
- What software version did you create the show in?
- Have you saved the show, then deep cleared the console, and reloaded the show file to see if this behavior continues?
