So now, with the newest iRFR update, at least it give messages when it crashes. This is what I'm getting:
Socket Read Failed
Socket is not Connected
Any ideas what is going on?
Socket Read Failed
I'm getting this error too. Also it seems, when i select my LED cyc lights, the colour picker on the iRFR does not work, unless i use the encoders to select a color and then the colour picker will be activated.
I am not seeing an problems the iRFR color picker, but it could be related to a specific fixture type. What fixture are you using for your cyc lights?
I am also getting this error message. I had an older version of the EOS software running and now I am up at 1.9.10 and am still getting this message. It is both on my iPhone and iPad (with current iRFR software).
Ok after spending a couple of hours testing different settings this is what I came up with
Make sure [ ask to join networks is on
go to each WiFi that you might pick up in the theatre or building your are working in
except the one controling console
and tell it to forget this network after doing this I would only get bumped was when i was out of range
But with in about 30 seconds after getting back in range it would reconnect on its own and shortly after that the app would link up
at worst i had to go back to the welcome screen and reconnect and i was good unless i went out of range again
not sure if it is even possable to link a specific WIFI with an specific app
hope this helps
Hi Guys,
The update for the iRFR app contained half of the fix for the connectivity issues. The other half of the fix had to be made in the console software, which will be released as part of the upcoming 1.9.11 patch that is now in the final stages of open beta.
You may still participate in open beta if you need the fix ASAP:
I had the same problem after upgrading the iRFR app on ios 3.1.3. Deleting and reinstalling iRFR on the phone solved the problem for me.
