BUSKING WITH SUBMASTERS and CUE LISTS
If a submaster is set to Intensity Master, why do I not have a flash or bump button?  Can you give the top button a toggle state so that we may choose between GROUP SUB select and BUMP?
Same thing with cue lists on playbacks.  I understand you only provided two buttons to work with...  It would be nice to have a toggle mode for the top button so I could GO to the cue in the list i want, then bump it on with the button or ease it in with the fader.
