Rate/Hold
A quick question,
While i was playing with rate, a function I havn't used that much. I was looking at the Help pages.
When I looked at the help page for the {Rate} key found after pressing Effect It came up with.
"Rate/Hold.
The Second press of this key places a hold on a cue. Hold leaves the intensities on the playback potentiometer to allow these intensity to be manually controlled once the fade is completed."
-Cue 5 {Rate/Hold}{Rate/Hold} [Enter] - Places a hold attribute on cue 5.
So i tried to play with 'Hold' and kept getting a syntax error after the second press of rate. I've not heard about the function and a quick search on the forums didn't come up with anything. Can anyone shed some light?
It also worth noting that the help page for the help key found after pressing [Effect[ is different to the one after pressing [Fader Control] on the Ion. I realise the fader controls rate does something else with load.
[edited by: Sammy at 11:03 AM (GMT -6) on Sat, May 5 2012]
