Show + RDM-Fixt.
Folgendes Problem:
Lustr+ spielen in mehreren Vorstellungen/Shows in jeweils einem anderen Modus mit.
Wenn Device Discovery akitiviert ist nimmt ja nun aber das Pult die Einstellungen vom Lustr+ an und nicht umgekehrt.
Ich hätte aber gerne das der Scheinwerfer, wenn ich eine Vorstellung einlade, sofort und "von alleine" in den für die Vorstellung notwendigen/richtigen Betriebsmodus wechselt.
Habe versucht ein Macro dafür zu bauen, aber leider ist in der Aboutanzeige der Adresse des RDM-Scheinwerfers/Lustr+ ist Schluß...
Hat jemand eine Idee oder könnte man dafür eine Funktion in die Software einarbeiten?!
Danke und lG
Linus
  • English Translation:
    Using Lustr+ in Eos Shows in different modes, dependent on
    which show is being used.
    When device discovery is activated in patch, the console
    reads the modus from the Lustr and uses it.
    Is it possible for the Lustr to automatically take over
    the Mode that is saved in the show file?
    Tried making a macro, but it didn't work trying to get into ABOUT.
    Anyone know if this is possible? To have the D40 to switch
    its mode to the mode in the Show file? Or is it possible to have
    this possible in an update?
  • This is a problem with other RDM fixtures as well- EOS device discovery overwrites fixture types in the existing showfile without warning.
    Fro example, I have a bunch of Ocean Optics Seachanger XG color changers.  When RDM device discovery is turned on, the EOS changes them to "Seachanger 4 chan"- which maps the fourth (green) wheel to a dimmer wheel and links it to the intensity attribute.  Therefore, when you fade the channel intensity up the green wheel rolls in.
    This is in part because the Seachanger's RDM response string is the same for all models and doesn't differentiate between the XG and dimmer wheel types.  Ideally, the Seachanger would respond with a different response for each model so that EOS could pick the correct fixture type.
    On the EOS side, it would be good if there was some way to reconcile the information in a show file versus the results of RDM discovery and not have the console change fixture types automatically.
    -Todd
  • Todd,
    I am having this exact problem with my Seachangers. Do you know of a solution, or am I going to have to assign the intensity to a different channel?
    -Michael
  • Michael,
    My current solution is to disable Device Discovery (in the Patch tab) once the Seachangers are patched and then change the fixture types to "Seachanger XG  4chan".  As long as you don't re-enable Device Discovery, the fixture types won't be changed.
    -Todd
  • Todd,
    That worked! Thanks!
    One more question: Is there a way for me to tell just by examining the Seachanger unit what model I have? I have inherited these Seachangers from an ME who apparently doesn't believe in documentation, and I've never worked with Seachangers before...
    I have determined based on the addressing that I have the 4 channel variety, and it's quite apparent that I don't have the HID or wash models, but I also saw that there is a "Seachanger XM 4chan," and I have to admit that I wasn't sure what that meant. Is there a difference between XG and XM?
    Thanks again.
    -Michael
  • Michael,
    The Seachanger XG has a green parameter along with the CMY.  And the Seachanger XM has an additional Magenta parameter.  I would recommend patching either profile and using the encoders one at a time, see what color the 4th is.  I am not sure if there is any designation on the unit itself.
    Todd,
    You have the correct workaround for the RDM devices.  Once you have discovered the devices, disable Device Discovery and you can repatch it as the device type that you want.  If Device Discovery is enabled, Eos will always use that discovered device type and won't let you repatch it to something else.
    [edited by: speterson at 9:33 AM (GMT -6) on Wed, May 16 2012]
    Michael-
    The best way to tell would be to give Ocean Optics a call and give them your serial numbers so they can look them up.  I didn't see any indication on the fixture's nameplate as to what type ours are.
    When we bought our Seachangers in 2007/2008, they were 6 channels (Cyan, Magenta, Yellow, Green, Reset, Timing) but at some point Ocean Optics switched to only making fixtures with the 4 channel personalities.  Depending on when you bought the Seachangers, you might still have the 6 channel versions (if you do, you might also have other issues with RDM- our units were reprogrammed to the 4 channel version as part of fixing the RDM bugs).
    -Todd
  • Thanks for the help, all. I figure that since I was having the problem with green being linked to intensity like Todd was, I must have the XG unit. It appears that the "XG" and "XM" profiles are identical since the 4th channel controls either green or magenta in any case.
