Clearing a Sub or anything else from the Fader Wing.
Hello all,
I've searched the forums to no avail, and I'm sure it's come up, but...
I recorded subs into my faders and then wanted to organize them differently.  Went to clear the fader, with no luck.  Went to record over them and it changed to a proportional master for the replacing sub.  Deleted the sub and it kept the sub assigned but so when I recreated the sub it just went back.
Maybe the proper terminology would be how do I re-assign, or de-assign a fader on the wing?
Jim
  • Hey Jim,
    Use the shift key in conjunction with both buttons under each fader. So push and hold Shift then push each set of buttons for the faders you would like to unmap.
  • Hi Jim,
    It partly depends on what version you are running. If you are on 1.9.8 or up you can use [Shift]+[Load] to unmap a fader. (Load is pressing the two buttons under the fader together). You can then select another sub i.e. [Sub] 2 [Enter] and then press [Load] to map that sub to that fader.
    Alternatively go to Displays > Setup > Show > Show Settings and select 'Fader Configuration', here you can set what each fader does by selecting the option from the four available, then tap the button at the bottom, enter a number and then hit [Enter]. Tap {Close} then {OK}.
    Hope that helps
    Dan
