offset not functioning properly with the use of + in the selection.
offset is not correctly selecting channels when the selection includes thru and plus it does not select the correct channels. Instead it selects the first set in the offset. I tried this on an existing show file and also offline on a new file. offset works fine if you only use through. offset works fine if you record the selection as a group example ch 1 thru 3 plus 21 thru 23 offset 3/2 selects channel 1 and 21 instead of 2 and 22 I also tried ch 1 + 2 + 3 offset 3/2 selects channel 1 Eos 8k primary and backup 1.9.11
[edited by: Druuka at 5:38 PM (GMT -6) on Wed, May 30 2012]
