Hi There,
We are currently installing Acclaim Dynaflood QA's in our venue as a sort of curtain warmers and need a profile for them. Acclaim makes two variants, in terms of color and DMX addresses. The QA (the ones we have) are RGBA and the QW are RGBW. Each can be operated in 8-bit and 16-bit mode. The DMX information should be on page 17 of attached manual. Not sure if it matters for future things or not but these come in 20°, 40°, 80° (the ones we have), and 20°x60° flavors. Also, we are going to need a profile for LightDesigner, so our Paradigm system can operate them... Though that is probably outside of the scope of this request. Please advise on how to proceed with that. In terms of timeline, obviously sooner is better, but we can get by for the time being.
Tristan
dyna-flood-qa-qw-guide-v1-2a.pdf
in the mean time you could use from the "manufacturer" Generic the fixture LED RGBA 16bit
Hi there,
I am submitting a fixture request to both the Eos and Paradigm teams. Based on your timeline, I will request an expedited process if possible.
Best,
Therese
Hi!
I think I am missing the DMX parameter chart. Do you have this available or can you point me to the place in the manual this is referenced?
page 17 of the above linked pdf shows it's RGBW (which is for the QW version) and RGBA (for the QA version). somewhere else it says that there is a 8bit and a 16bit mode. so it lookes like there should be a QW 8, QW 16, QA8, QA 16
