Prolights new personality request: ECLCTPLUS
Hi there,
I would like to ask you to create the library for Prolights_ECLCTPLUS.
You can find the manual here:
/cfs-file/__key/communityserver-discussions-components-files/191/Prolights_5F00_ECLCTPLUS.pdf
Thanks.
Best regards.
  • Dear support,
    I’m Paolo Ciccone, library manager at PROLIGHTS and I’m writing to report some feedbacks we’ve collected from various EOS users to address some issues they met using the personality of ECL PROFILE CT+ available at ETC OES website.
    Please find attached to this report, an updated user manual
    We have also addressed some naming on parameters that perhaps could have brought you on mistake.  We have actually added two new mode with RAW over the 6 colours for users that love to use the EOS color system.
    Find following a list of feedbacks collected in order the used parameters:
    COLOUR MIX 1/2/3
    It doesn’t work in EOS color picker at all.
    As you do see in the manual those 3ch are set by the users to be RGB or CMY or HS… So in order to be correctly used by the console you should duplicate three time the personality and change in the personality to be:
    BASIC (RGB) ; BASIC (CMY) ; BASIC (HSI)
    STANDARD (RGB) ; STANDARD (CMY) ; STANDARD (HSI)
    EXTENDED (RGB) ; EXTENDED (CMY) ; EXTENDED (HSI)
    COLOUR WHEEL:
    This is a Virtual Color wheel, so a SNAP channel and NOT a linear channel, please update the parameter naming and type.
    We have added a gel ref. No in the naming, and Color coordinate x,y of each of these color preset. Please update naming and possibly make the association of these color preset into your gel library of the software.
    COLOR WHEEL SATURATION:
    We changed the naming to make it more clear that this is a Saturation channel that works ONLY on color wheel and NOT on Color mixing.
    CONTROL Channel:
    Users reported that several of the CONTROL were wrongly associated to Lamp control… like fan settings. Can you please verify?
    Moreover please use 3seconds as standard timing to apply a Control/Command.
    NEW USER MODE: RAW Direct and RAW16bit
    EOS users would like to use the EOS color engine to control the luminaire, so please can you include in the library these two new mode as indicated in the User Manual?
    CALIBRATED library on EOS:
    They are asking to talk to you to obtain a calibrated library for the product in EOS. Since we do already do this for GDTF, What informations do you need to insert those data?
    We can provide X,Y,X and spectra wavelengths chart for every primary of the 3c and RAW mode. Would this be sufficient? We do use A Viso photogoniometer and Asensetek colorphotometer.
    We have got a couple of EOS users who are soliciting to have this update to be done soon, could you please let us know when can you upload the revised library?
    If you have any question please do not hesitate to contact me back.
    Best Regards
    ECLCTPLUS_user manual_rev_11-11-2020.pdf
  • Just as an update, your additional information was passed along and it looks like this has been incorporated under the Prolights ECL Profile CT+ profiles.
