Hello,
The TILT Paramater in the A3d is strong deviating from the physical value. With 90 ° of physical position points software EOS and accordingly A3d approx. 109 °.
https://www.glp.de/en/products/moving-lights-led/impression-x4
Hello,
their website says this:
Eos currently thinks Pan is 660° and tilt is 300°
does it work if you go to the fixture editor and change the pan range to -311.5 to 311.5 and the tilt range to -147.5 to 147.5?
-147.5 to 147.5?
With these values, the position was also not correct.
I adjusted the minimum and maximum values to match tilt +/-90 ° physically with A3d.
Thanks for the tip! So I immediately adjusted the values of other fixtures.
what were the actual values you used for the x4?
That's where I need to check. I'll check it out tomorrow.
Tilt -126 > 126
