"Cameo ZENIT W600", a Washer and Strobe.* I'm looking for modes that support "Duration" (which is sadly missing in the lower modes): 39CH Mode (also fine: 42CH, 48CH, 54CH)
www.cameolight.com/.../zenit-w600
* For EOS v3.x* Its relatively urgent, festival is running already, Fixture will be used on July 18th :/Thanks!
No hope?
If it is ok, i can give you a hand.
One more Question, are you sure about the this?
mfo said:I'm looking for modes that support "Duration" (which is sadly missing in the lower modes): 39CH Mode (also fine: 42CH, 48CH, 54CH)
Because the Manual only say that the Fixture has 2Ch, 3Ch, 4Ch, 8Ch, 10Ch, 15Ch - Mode
Good find! I meant the "Cameo ZENIT W600 SMD" - it a newer model/upgrade.www.cameolight.com/.../zenit-w600-smd
Hello,here is a selfmade Showfile with the 4 Modes. Also a Spreadsheet with a documentation is attached.
I only tested some Functions with my DMX-Tester to see if it works out.
So it is basicly untested.
If you have any trouble please mail/PN me or call me.
Yours
thilda
Cameo - W600 SMD 2022-07-13 21-19-02.esf2
Doku - Cameo w600 - SMD.xls
I have this request Submitted. It is very unlikely that we will have a fixture library available with this profile by your deadline. I recommend you try the profiles written and linked here by mathilda .
Thank you so much! I will test it next week in the venue.
I was pointed out that the Patterns in 39Ch Mode were a bit difficult to access.And while looking into this i noticed a little error.
- I came up with a fixed 39Ch Mode for the Effect Macros (values were not right)- made a v2 of the 39Ch Mode for quicker access of Effect Macros (Pattern)- made a v3 of the 39Ch Mode with a added Mode for the Effect Macros (Pattern) and access should be much better
For anybody to decide wich version is to your liking.Please note that in the v1 for the Effect Macros [Shift]+[Encoder] is needed to scroll through the different Effect Macros(Pattern)!
Cameo - W600 SMD v1 2022-07-30 03-24-10.esf2
Cameo - W600 SMD v2 2022-07-30 03-07-49.esf2
Cameo - W600 SMD v3 2022-07-30 03-28-01.esf2
3162.Doku - Cameo w600 - SMD.xls
These profiles are now available on our website in Fixture Library v3.1.3 build 2.
Apparently an other fixture, than originaly intended, was added.
mfo said:Good find! I meant the "Cameo ZENIT W600 SMD" - it a newer model/upgrade.www.cameolight.com/.../zenit-w600-smd
The new lib has added • Cameo - Otos H5 & Thunderwash 600 RGBW
Ah yes. My apologies. the Zenit W600 is in the library, but not the W600 SMD.
