Planned for Future
Allow command line shutter syntax for conventionals in patch to support incremental change from existing value
I can use a macro along the lines of Select Last Shutters Frame Thrust A and then enter a specific value, but I can't use Select Last Shutters Frame Thrust A @ +01 which, if supported, would allow one to make a magic sheet or set of direct selects for fine control of the shutters in patch when working with an offline editor.
tt2
