more Alert Time functionality
thank you for the alert times, they make my life a lot easier!
i was wondering if these features could be added:
  • count down past 0 into negative numbers
  • visually highlight the currently counting number, with a whole column of alert times it's hard to see at first glance which number is actually doing the countdown. maybe have a grey tint in the cell background?
  • it's hard to tell at first glance which are long times and which are short, the difference between times with minutes:seconds and seconds.tenths isn't quickly visible. maybe have the seconds.tenths displayed as 0:seconds while static and only show the tenths when the time is actually counting down?
  • during countdown the [Display Timing] button (half moon Time button) should show the full time, as it does with other countdowns in the PSD
  • when re-learning a time the red count-up replaces the time that's already been there. could the previous time be shown in parentheses so it's easier to compare the current to the previous time?
thank you.
  • Also - Learning Alert time in sequences with follow cues is not logical. In my view, when learning the alert times on sequences with follows, the cue that follows should have the exact alert time as the follow time in the previous cue. Currently it either defaults 0.1 if learning for the first time, or it does not change values when overwriting learned alerts if a value has been manually entered.
  • +1 on negative time counting when cues are "late"
  • It would be nice to have the Alert Time as a button / object for the Magic Sheet, maybe with the options: General/Cue/Cuelist.
    It would be a nice addition to the little screen in the middle of the Apex consoles.
  • I really like this feature too, and I would like to implement it in my app (a bridge between an XTouch controller and EOS).
    Could you add an OSC access ? Like remaining time, total time, learning status and may be an indication if the next step is auto (hang/follow).
    And, the same way, could we access it in magic sheets ?
    Thank you !
  • I'd also like to see improvements when using alert times with looped cues. Currently only the last learned time will be stored, however it could be useful to store different alert times for each loop iteration since the times could differ.
    thank you.
