Can the ability to sneak or delay a range of times across multiple channels in live please be added? For busking, the ability to "roll out" a focus palette, beam palette, color palette or preset over a fanned timing would be beneficial. For example: "Chan 111 thru 131 [sneak] 5 thru 8..." or "Chan 111 thru 131 [delay] 5 thru 8..." should be valid syntaxes (though they are not currently).
This is a repost from 3 years ago in the old Eos Feature Requests feed, just want to make sure it keeps on track.
The current workaround i'm using is from David Kane to put Q1 on its own fader and 111 - 131 to have discreet timing values desired applied to them and are recorded using the "staggered" FP. Then I use a macro that copies the FP you want to use the "Staggered" FP. Now "Go" on Q1 will play back the correct FP in the desired fanned timing.
