Feature Request: Hybrid LED Dynamic Adjustable Color Temp using multiple addresses
It is common in the film/tv world to work with random LED dimmers and Hybrid LED tape or panels.  On common cheap software (luminair) people can patch 2 addresses to a color temp parameter and give it a low and high value to scale between.  It would be incredibly helpful to have this on EOS as well.  Obviously the color temp is not a true blend between the two points and is usually far off, but this is what DPs and Gaffers are used to when coming from smaller shoots.  Having the option would be incredibly helpful, even if we ween them off to the proper way of calibrated palettes or a dimmer/led that compensates.  It's never fun telling the bosses your much more expensive system can't do something seemingly basic.
Parents Reply Children
  • I like that solution, though you are saying you do that with 30-100 different hybrid LEDs?  A fader for every one?
    No, I use color palettes. I was just trying to offer suggestions.
    Also, you only really need one fader. You can use a macro to re-record your submasters, something like:
    Delete Sub 1 Enter Enter
    [Select Last] {Color} Record Sub 1 [Enter]
