I have some LED Par 64's. When I go into the Patch menu and edit a fixture, the LED cans flicker everytime I press the arrows to move across the screen. Anyone know what that is about?
I'm actually using a Hog500 (I meant Hog II OS) so I am using the patch button
It actually happens when I save as well (when I hit 'OK' to save) also when I hit 'add fixture' and when I hit 'ok' to exit the 'set up - shows' menu (but not going into it)
To me it sounds like you are using some old software. I know the Hog II's would make the lights flicker when saving, but I have not run into that on the Hog 500/1000. Try updating the software.
[quote=TimMiller]To me it sounds like you are using some old software. I know the Hog II's would make the lights flicker when saving, but I have not run into that on the Hog 500/1000. Try updating the software.
I have a Hog 1000 on the latest code, and it goes dead as a doornail to stage when saving, same as the H2. IIRC, the last time I tried to do a fixture edit with things live, I got a blackout . . . . I think it may just be the nature of the desk. I'd verify that, but the console is packed up in the shop right now . . .
