Can you give me some additional information about what you're asking for?
Are you saying that when you reset a client console from the network window that you want it to automatically log back on to the show it was connected to?
Or possibly that you want an additional Auto-Launch option to reconnect to a network show? We would probably have an option for connecting to a network show and we could show a drop-down list of all shows that are currently active on the network.
I would like to have the Reconnect button similar to Exiting show button in the Start window. I want to be reconnected client console by the same setting as the setting used at last show with this button.
YES
[QUOTE=teerickson]Or possibly that you want an additional Auto-Launch option to reconnect to a network show? We would probably have an option for connecting to a network show and we could show a drop-down list of all shows that are currently active on the network.
Mummh ... Drop Down means that you have to select it . what I'm asking it's an option to reset the remote Consol and let it back exactly where it was .
I was thinking that the drop-down list to select a network show would be on the Auto Launch tab of the Control Panel. This would allow you to choose the network show that you want to auto-connect to. If that show is available when the console is restarted, it will automatically connect.
Why did you put DHCP in your post? I'm not sure where this entered into the discussion.
Currently I believe that we only have the server console IP address available, but I don't see why we couldn't publish a show name with the information that we broadcast.
