I am unclear as to exactly what you are asking. If you ordered one the HES Hog 3PC keyboards (www.highend.com/products/controllers/Hog3PC_CustomKeyboard.asp) then it should just function with Hog 3PC. There is no where to select a "program" for it on a list.
If you are refering to a programmer wing, there is no configuration required within Hog 3PC either. It should just function once the USB driver is installed via windows. Refer to section 30.1.5 of the Wholehog User manual for further details.
If you have some other device, please let us know what it is and we will try to assist.
Brad is correct. The Hog 3PC keyboard that we sell uses generic Windows keyboard drivers.
If you are having problems using keyboard shortcuts within Hog 3PC, check to make sure keyboard shortcuts are enabled. They can be turned on and off with the Pause / Break key. When keyboard shortcuts are enabled, you will see MAP on the right side of the command line toolbar. When they are disabled, this will read Abc.
Sorry for the confusing question it was one of those late night programming in the studio nights thanks for the replies tom answered the question it is a high end shortcut keyboard and the shortcuts were disabled
I hope this helps.
On macbooks you cannot do this.. ridiculous... So i found the program "Auto hotkey" wich will let you script custom macros from any keystroke.
