iPC 3rd Touchscreen issue
Hi All,
Hog iPC
XPe Image 8.0.5
v2.2.2
I've read other threads on this but I need to throw my hat in to the ring. My 3rd Mnitor, (an ELO 17" touchscreen) connected to the DVI output using a DVI to VGA adapter loses it's touch capability shortly after it's been configured. I've tried the workarounds noted in other threads to get the monitor to function and for the most part that works. I get display. I can move windows in and out of it. I get touch response and can select using the mouse. Within minutes, 3 or less, it loses it's touch. Display remains and I can move windows and use the mouse but, no touch. Also, in Control Panel>Displays the 3rd monitor disppears from the monitor list. Ideally, It should work all the time every time, no? Any help would be greatly appreciated.
