Hardware: iPC with A78NX-VM/400 motherboard, 2 x original 12" ELO touch screens, mouse & keyboard, no network connection.
Hi Chris, et al.
A quick note regarding a problem we had during v3.0.1 (re)installation on our iPC today. 1. changed video buffer to 8meg in bios. 2. full install of v8.3 from XPe image 3. upgrading ipcconfig v3.0.1 and h3pc v3.0.1 from thumbdrive via iPC config panel. 4. removing thumbdrive and rebooting the iPC. 5. loading the show from backup on another thumbdrive. 6. None of the cuelists would play, they would 'release' themselves immediately, but would step through the cues (no output). I rebooted the iPC, launched the show, desktop was 'not responding'. I removed the thumbdrive, rebooted the iPC, launched the show, and everything is ok... The thumbdrive didn't have any other files apart from another show backup.
Name: Cormac jackson Date :18th Feb 2009 Console:IPC + Super-widget + USB wing
just wondering if it is possible to return the video frame buffer size setting in the bios back to a higher setting after installation or is that not advisable?
My IPC console was set to 32mb before i changed it 8mb to get v3.0 installed correctly can i now return it to 32mb.
Also as i have not used V3.0 on an IPC up to this point can someone clarify that instead of seeing my super-widget i should now see a DP8000 instead in the network settings. I can't seem to add a super-widget in the patch section just a DP2000 or DP 8000. Should i remove the Dp8000 and add a DP 2000 or will everything work correctly?
The DP-8000 is the new process as of v3. This replaces the previous (x2) DP-2000 processes to handle the internal widget and optional superwidget or single widgets.
To configure an extra superwidget simply select the interal DP-8000 from the Netowork Status window and select Settings at the bottom....you no longer configure extra widgets under Control Panel......the Release Notes have more detailed info if you need it.
