Lost Internal DMX Widget in iPC HELP
Suddenly lost the internal DMX widgets in the iPC after pluging in a Road Hog Playback wing on my ipc. Software 3.01 says that there is "none" in the network settings for the DP8K. Tried reinstalling the software from a system restore, but no luck. I was running a show tonight with no problems until I plugged in the wing. iPC is running 2 other normal playback wings and has been for a long time. In the info section of Control Panel, it reports that the internal widget is there, but the software does not see it. I plugged in an external widget, and it sees and recognizes the widget. HELP! need to fix this ASAP as I lose the external widget.
Hog iPC
Build 3.01
iPC image version 8.03
AMD Sempron 2400
503 Megabyte
