Fine Values
IPC :Version 3.01
Attached : Playback Wing/Monitor/USB keyboard
I'm having some issue with some DL2's and an IPC.
Basically I'm getting issues with reliable playback of palettes.
If i program my fixtures with say a pan degree of 91 and replay the cue the position is out.
If i then open the que,que que and touch the encoders i can see the values at 91 degree's?
This is across all fixtures,again if i hold down pig and pan the fixture's i can move at least three movements within 91 degrees which although a tiny amount is massive when your making a collage.
Solutions please.
I've tried running the fixtures to the end-stops and making big movements to try and get the programmer to latch or record values but no luck.
Regards Cormac
