Macros and grouping
Hi All,
3 things that have been bugging me for some time, just never got round to asking:
1, why in my cuelists do other masters release when I go to the next Q.
eg...
Cue 1 All washlights red
Cue 2 All washlights green (GM2) (starts LED Chase)
Cue 3 All washlights yellow
as soon as I hit go and move to cue 3 master 2 will release, i have to keep adding a GM2 to every Q to keep the the effect running
whats am i doing wrong.
2, is there are way of selecting groups of lights and breaking them into sub groups of 3 or 4 say like a mask
3, In the effects engine how do I get the effect to start from the center of a group of lights. ie i have 30 colourblocks and want the effect to start from the 15th & 16th block and run out to the 1st and 30th block, I have seen the different options on the bottom of the RH Touch screen but they dont seem to do anything.... what am I doing wrong.
Thats all for now,
Dave.
  • Hi Dave,
    In regards to #1, I think this is a case of your cuelist is "stomping" on the previous list, since they both are trying to control the same values and the Latest takes precedence rule comes into effect. Try setting the chase cue list to "Persist on Override" and give it a higher priority than the other lists in the options menu.
    For #2, once you have your group selected, you can use the "Select" toolbar, Section 15.1.3 talks about this in the manual.
    I'm definitely not the most proficient in using the effects engine but I think you can do what you're looking to do by selecting the fixtures starting from the center and then moving out. You could select fixtures 15 thru 1(in that order) apply the effect and then copy the effect to fixtures 16 thru 30. There might be a better way to do this though.
    Eric
  • When you are doing an effect, select your effect, then hold down the fan button. On the bottom of your right screen you will have 4 options for order: Normal, fan from start, fan from end, fan to centre. I think the last option might be the one you want.
  • Hi Guys, thanks for the help the macro thing is weird, I am fully aware of the LTP thing and stuff getting stomped on but even if there is no NEW information in the next cue it still kill the triggered master, the next cue does have tracking information in it but no new info..... its very strange... I'm going to try it again tomorrow and see what I come up with, thanks once again
    Dave.
  • Hi Dave,
    Even if there is no new information in the 2nd cue - so the information is tracking - when you go the next cue the console is still calculating the track (so the current State of that master). If you don't want anything being stomped I tend to up the priority and choose Persist on Override. That tends to do it.
    As to the effects engine - if you have 30 lights, and Fan with the Center Option, this should do the trick.
    I know it's not an effect engine, but for anything where I need precise Fans from certain positions, then I build a Delay chase (Fanned delay on the Timing). That way I can have the ripple from any point I want.
    P
  • Hi Pryd,
    Thanks for that, I knew I was doing things right, just seemed to remember that hog 2 didn't do this..... maybe it did ? i cant remember now... as for the effects things I do the fanned delay to create these effects, I just saw the button when holding down FAN but it doesn't seem to fan from centre for me,
    Catch you soon,
    Dave.
