[Record] {Selected} with nothing selected records everything
Grab some fixtures, set them to some values. Hit backspace a few times to deselect everything. Hit [Record], then {More...}{Selected} [Cue#][Enter].
Instead of recording an empty Cue, everything is recorded. Hog II would make a blank cue. I want a blank cue. Logically, I should be getting a blank cue.
This is very useful when the designer tells you, after you've modified a bunch of stuff in an existing cue, that they want to record this, but then wants to add a new cue (before the next one) that restores everything back to what it was.
On Hog II, I could just record the new cue as a blank cue (as above), and then record the existing cue with {Forward} deselected.
