Smartfade ML W/ American DJ profile panel issues.......
Hey guys,
I will be getting my Smartfade ML today!!!
I've been reading in manual on how to create a user personalities, and I have found a problem on how to control the ADJ profile panel( http://www.americandj.com/ProductDetails.aspx?ItemNumber=1931&MainId=2&Category=L.E.D. )
My  problem: You can operate the panel in 1 complete square, or you can "cut" the square into 8 sections. with the smartfade ML you only get hue and saturation. 3
How can I control all 8 parts without using multiple devices or using Intesnity channels on the SF ML? Thanks!!!
  • Hi there -
    This type of fixture will require that you use 8 device channels to control the 8 sections individually. SFML cannot control the separate sections under one device number.
    Thanks much -
    Sarah
  • Hi Sarah,
    Could You trick the board into thinking that fixture's DMX is not that it is? EX. Fixture's DMX channel for the 4th block: dimmer, Board's attribute fader: frost?   Does that make sense?
    Thanks!!!!!
    [edited by: lightingguy1 at 7:06 AM (GMT -6) on Fri, Jun 11 2010]
  • Hi there -
    Yes, technically you can build the profile any way you want to, however if you plan to use palettes or effects it could become quite complicated since you're now controlling color parameters on non-color faders, if you know what I mean. You'll have to determine what's going to work best for you in your situation.
    Thanks much -
    Sarah
  • Hi again,
    Coming from an expression 3 the word, effects, Kind of throws me. What is an effect on the SFML? Thanks again, and many more times in the future!!
  • Hi there -
    I would recommend you take a look at our tutorials. :-) They should be helpful and answer a bunch of questions.
    http://www.etcconnect.com/support.tutorialseries.aspx?seriesId=3
    I hope this helps!
    Sarah
