Hi
When Selador is operated by SmartfadeML, it is only R/G/B which is controllable by HUE/SAT.
Are seven colors controllable by HUE/SAT?
Best regards,
Kani
Hi
Best regards,
Kani
The next version of software is in the last stages of development and testing. It will provide full Hue/Sat control and colour effects of all Selador colours and for other devices with more colours than RGB. The present version only controls RGB via Hue/Sat and the colour effects system.
The next version will be out as soon as we can complete full testing.
Hi Adam
I expect the next version.
Thank you.
Kani
Any timeframe when that new software will be out?
We will be showing it at the PLASA show and releasing shortly thereafter.
Hi Brian,
there is not yet a profile which alles complete Hue/Sat control of all 7 colors for the Selador fixtures in the Smartfade Library yet.
The next software version of Smartfade ML will contain better profiles for the Selador fixtures; this software update will be available soon.
Actually Corey, the Selador is already available in the SFML Library v5.5.5, which can be downloaded from the downloads section of the ETC website here:
http://www.etcconnect.com/docs/docs_downloads/console/SFMLLibrary555.zip
It can be found under "Selador" > "X7" - this personality is the same for all 7-colour Selador units in v2.1.2.
As mentioned previously, the Hue/Sat controls in SFML v2.1.2 only control Red, Green and Indigo colours, with manual faders for the other colours.
In v3.0.0 of the SmartFade ML firmware this is greatly improved and will include additional personalities for other Selador variants, such as Fire and Ice.
Hello,
We are interested to hear if you have been able to try out the Beta version 3.0 and if you are satisfied that it works and runs Seladors in a useful way (and better than the previous version!)
Thank you,
Adam
