No doubt I am doing something wrong. On the Smartsoft simulator Patch tab, I drag outputs from the lower part of the screen to the upper part (on channel 1). When I hover over CH 1, it lists the outputs I had dropped on it. However, when I activate the control surface and move slider 1, I don't see the lights I patched follow the fader. Rather, I only see light #1 active. Then, after I save the show and examine the text file, the table of patches doesn't reflect what I did on the Patch tab
So I am lost. Smart fade uses the term output and DMX cell while the Smartfade uses Channel and Dimmer.
Is it possible to create patches in the simulator? Any ideas what I am doing wrong? TIA
