I see someones created code for a 6 fader wing box, is there any documentation for this like a components list and wiring diagram etc just like Box 1?
Hello, the nano is a no go, that means I have to rebuild the whole thing including code. But it works fineon MAC OSX even without a IDE install, plug it in and it works. Somebody wanted to borrow it, he runs WIN 10, and that did not work. It is visible in WIN 10 device manager as micro. So I think I try the work around with the PIV VID and or the full IDE install.
Hello! I see you used a teensy 3.5 board for this project, but since the teensy 4.1 is a lot more common nowadays... would it work the same without issue? I want to create something similar but havent bought components yet
Thanks for any help!
It should also work, maybe an Arduino Nano Every is cheaper, but not tested. Have also a look of the hints about grounding.
