Upgrade Cyber CX with CL parts?
We have an operating Cyber CX, plus a non-operating CL. The CL's electronics are shot but the hardware is ok.
Is it possible to make a "Frankenstein" Cyber with the CL's parts to add CMY, frost & zoom to the CX?
Cheers,
Scotty.
  • Please define "shot" . . . there is not much that can't be fixed pretty easily on a Cyber . . .
    - Tim
  • Good question - no PSU board (as in absent), logic board questionable, no eprom chip, no power factor cap (granted, not a huge issue).
  • I think the PSU is the same between the two. The prom should be as well, and they are pretty cheap to get (just don't use HES . . . the part is about $3, if you can load your own image) and the cap is the same. The logic card is listed as two different part numbers - likely the drivers and stuff for the focus and zoom motors isn't on the CX card. At any rate, to get the CL going, it might work better to move the CX parts to it, and go from there. The only thing that could stop you would be the logic card, and since you state that there isn't any evidence if it actually being dead, it might be worth a try . . .
    - Tim
  • Thanks Tim. Will have a go at Frankencyber and post how I go.
