Hello I have an hold studio spot 250
the homing is very long and he give me a home rot1 err when he finally finish the homing procès
Anyone have a tips for fix it
have a nice day
have a nice day
I am not completely familiar with this product, but based on other moving light knowledge I think it could be one of a few things.
If the wheel is rotating during homing you probably don't have a motor, driver, or wiring problem. Unless its movement is really jerky or inconsistent.
If the wheel keeps rotating round and round, you either have a problem with your sensor, the magnet on the wheel that the sensor interacts with, or the wiring to that sensor.
I would start with the magnet, and then go to the sensor, and check wiring last as it can be challenging.
I was informed that these fixtures likely used Optical Sensors, which means that a magnet is definitely not a factor.
According to High End Systems Service, it is possible that it is a motor failure, with fixtures this old it could be warped and binding on something inside.
Feeling the motor by hand w/o power gives a good indication sometimes. If its stiff then the motor of the wheel is the problem, if it is not stiff then it may be the sensor, driver, or logic board.
Hi Nathaniel,
We are High End's legacy support center for their products including Studio Spot 250. Please visit www.lightparts.com or email parts@lightparts.com . We have all the old stepper motors in stock.
Thank you,
Robert Mokry
LightParts Inc.
thank a lot after some test with sunlite suite 3 all motor all dmx fonction are ok
i test the sensor of color and litho and fx wheel they are ok
all motor work
when i use dmx command or internal preset evrey thing work normaly
but when start the fixture after the homing process she tell me rot1 error
can someone says what is the rot1indicate : color ,fx ,or litho, pan, or tilt error
have a nice day
thank a lot motor are ok sensor are ok
a bug in the homing process ?
thank you i have a lot of the fixture and a anther one have a focus motor faulty
you send to france ?
