New DL-2 user, couple of questions
I've got a show coming up where I will be using 3 or 4 DL-2 fixtures, which I have not programmed before. I will be using an iPC running Hog 3 software to do this. I've been working my way through the manual, but I have a few questions I can't seem to get a clear answer on in the manual (might have just missed them).
- the console treats 1 DL-2 as 3 seperate fixtures. The fixture only appears to accept one start address. Is this correct, or is there a DMX start address in fixture menu for each 'console fixture', ie a global start address, motion address, and graphic addresses?
- Can I use the VGA input as an one of the 3 object layers?
