CS Pars - current draw?
So, because I'm dumb. I'm looking at the CS Par specs and I'm wondering why the limit is 9 units per 20 amp circuit?
At 120watts maximum draw per fixture on 120vac, that's only 9amps.
I can understand only pulling 15amps through the 15amp rated PowerCON connector, but we're not even at that point. Is there an inrush or something I'm missing?
I think I might have to pull 10 units from a single circuit and want to see if that's feasible.... but mostly, I want the numbers to add up & make sense.
