Axon Day 1
Date 9th January
Name Cormac Jackson
Axon Software 1.3.1.1208
DL2 Client software 1.2.3.906
Connected device's
Belkin Keyboard -USB
Belkin Mouse -USB
I'm using an axon for the first time and am starting from scratch so my first issue is.
Monitor's can't seem to get anything out of any monitor i plug in to the DVI port for the CMA or other the DVI for the graphic engine.
Have tried VGA>VGA cables and DVI>DVI with adaptors
On an ELO touchscreen i get the high end startup screen and then nothing else,on any other monitor i see nothing.
I have 1 blue LED,1 Green LED,1 Red LED and an intermittent Amber LED on the front panel.
I can see the Axon if i use use my laptop connected and DL-2 client manager and everything seems fine.
Am using an IPC in HOG III mode as control,
with the following and nothing else patched.
1 x DL2 global @1
3 x DL2 graphic @ 36,74,112
Grand master at full,global intensity at full,3 x graphic at 10%.
Any obvious suggestions or help appreciated.
CJ
