Console's 1-300 of universe1 and 200-312 of universe10, 1-100 of universe14, combined into a DMX512. Whether it can be implemented in the DMX output of Net3 gateway,?, not in the patch in the console
I think this could be done with a 4-port Net3 gateway and advanced Input Patch for three ports if you can get DMX out of the console with DMX cables:
You could use port 4 of the gateway as an output for Universe 1 to get the combined output.
Configure the Net3 Gateway with Concert software - the manual is at http://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737495774 and Advanced Input Patch is on page 87.
-Todd
This could almost work, except that sACN universe 1 output by the gateway would have an HTP mixture of data from before and after the gateway's merging impact.
Two options to tweak this and clean it up:
1) Remove the gateway from the network. That would isolate so the only sACN 1 the gw sees is what it is generating. (Note: You'll want the most recent gateway code for this. A couple of versions back there was an issue with unnetworked gateway function.)
2) Set all the AIP inputs and the output universe to a (matching) new universe--one that isn't used anywhere on the network.
good points - i didn't think about the universe 1 merging "loop" if the gateway is on the network.
I think a DFD (horrors a non-ETC product) protocol converter could do this all in network, then to gateways.
Similar to the table above, customize a Vport or universe,command:1-300*1.1-,301-412*10.200-,413-512*14.1-
