Im new to all this networking stuff and im trying to set up my Net3 1 Port DMX Output that ive had sitting around for a while.
Ive gone into NET3 Concert as the setup videos suggests and connected to my network however when i go into Find Unreachable Devices my Net3 doesnt appear.
Ive also tried GCE and followed the setup videos but it doesnt find my NET 3, however the Set Device Network Mode shows my Net3 port and its IP address, Type and App version, so i know that something is working.
The actual Net3 port has a blue solid light next to 'NET' and a green flashing light next to DMX
Any help or suggestions would be greatly appreciated!
First questions.... are you wired or wireless and are you in the correct network path .... is your Net3 port IP address something like 10.101.100.01? Your machine running concert needs to be in the same "universe" as your net3 network in order to communicate. If you're pulling a DHCP address you may not be on the right network.
Im running it wired
When i can see the Net3 in GCE its IP address shows as 10.101.50.117 and in the properties for the network i am connected to the IP address is 10.101.50.1 Subnet mask is 255.255.0.0
Does that information help a little more?
So you can see the gateway? I thought the issue was that you couldn't see the gateway? Does it not show up in your device library in Concert? If you're working with a project and it's already loaded into your spreadsheet/worldview you may not see it the library, but it will be on the spreadsheet. It's possible that your gateway is reachable and in your network, but could be in a different universe than you're expecting or restricted in another way.
This is the video i am following to try and set it up - https://www.youtube.com/watch?v=rkfWZlWcvtE
Ive done everything up to the point where they use 'Find Unreachable Devices'. In the video their device shows up however when i run it my device doesn't
(The only way i know something is right is when i open GCE and go into Device Network Mode my device shows up and shows the its ip address, but apart from that i cant see or do anything with it)
Ive added 2 pictures below so you can see what i can see if that helps
Does it not show up in your device library? an unreachable device is a device that does not show up, if you can see it the configuration editor I would expect you to be able to see it in your device library and not for it to show up as an unreachable device.
Ive gone into the Device Library and theres a load of icons there, i dragged the ETC One port icon (im assuming thats the device ive got?
From your picture there, that is quite an old device - it's one of the first generation of 1-port gateways. I think you may need to use GCE to configure it, not Concert (I'll double check that later) - but to get it to that point you might need to update it. I would start by following these steps and using GCE:
https://support.etcconnect.com/ETC/Networking/Gateway_Configuration_Editor/Updating_1-Port_Gateways_to_be_Configured_in_GCE
Yes it is quite an old device, bought many years ago.
I can get to the bit to Update Software then choosing the 'Selected network interface IP address' option and when i click 'okay' the Net light and DMX light flash and go off for a second then they go back to normal (Net light on and DMX light flashing) but nothing happens in the GCE.
I tried clicking 'Switch to ACN' after the update and again the Net light and DMX light flash and go off for a second then they go back to normal again.
In order to update your device, you would need the DHCP and Update services running. If in GCE you go to the Network -> Configure Network and Services screen, you need it to look like this:
My guess is that maybe the update service isn't started - you can start it from that screen. Once that's running, give it another try.
I’ve started both of them but still just the same outcome
