I have ION console and Sensor dimmer rack set for dimmer but some channels/dimmers area acting as they were set as non-dim as if I called a channel at @10% this goes to 100%, any advise? Thank you
Have you checked that the dimmers are not in switched-mode? You can find that under the "control mode" in your sensor rack settings for the dimmers
Hello everyone,
I just want to let you know that i have fixed my issue.
The issue was in the CEM, it was not sitting properly into the rack, I ejected it and put it back in, this time making sure it was a solid connection, after this Voila! All dimmer channels came back to operate as normal. I thank you very much for all your suggestions.
