I've ordered 4 fixtures like this : https://www.cameolight.com/fr/solutions/dj-musiciens/eclairage-statique/projecteurs-de-theatre/20479/ts-200-fc
These are Cameo TS 200 FC
In the latest library of my ColorSource (16.0.5) the two last dmx modes are 11 & 13 channels, but on the dmx table from the manufacturer it says 12 & 14 channels ( https://www.cameolight.com/fr/downloads/file/id/966404022 )
The mistakes are the same in both situation:
- channel 2 (dimmer fine) is missing, but there is a gap in the patch, so it's not a problem for next channels (but is it a normal behaviour ?).
- last channel is missing in the library. In both case on the manufacturer DMX table, the last channel (12 & 14) is the device setting, and the previous one is the color mode crossfade time (that don't seem useful). So I think there should be a gap here too.
I give tou an example for the 12 channels version:
The manufacturer table:
1 Dimmer / 2 Dimmer Fine / 3 Strobe / 4 hue / 5 hue fine / 6 Saturation / 7 Sat. fine / 8 Color temp / 9 Tint / 10 color mix / 11 Color Mode crossfade / 12 device settings
The console library:
1 Dimmer / 2 Gap (unpatched) / 3 Strobe / 4 hue / 5 hue fine / 6 Saturation / 7 Sat. fine / 8 Color temp / 9 Tint / 10 color mix / 11 device settings
So, is there a way to edit it by myself, or do I need to wait for an update ?
Thanks in advance !
