Congo Networking - Backup synchronization
Hi All,
I have a question about Congo Networking - Server, Backup. I think after Server crash Backup do not takes control from the moment of server crash. I need to use such installation for Theatre and work only with GO button to playback presets in sequences.
What I did:
1. Connected both Congos: Server + Backup
2. Send Play to backup ( * then only DMX Output 1 was FULL)
3. Then on server do few times 'GO' to playback some presets in sequence
4. Disconnect Server - I mean disconnected LAN cable from network
5. Backup changed to Server, but no DMX levels on output - there should be values from Server crash but is nothing.
6. I pressed refresh on Backup, there are levels, but these which were when send play to backup from Server (*), not from the moment I disconnected the Server.
7. If I pressed Go it started to playback the preset number that was in the sequence while I sent the play (not this from Server crash).
How to make Backup will continue the Server from the last moment of server working or some walk around.
Configuration:
Congo (Serwer) + Congo jr (Backup) connected with 2 Ethernet cables to Switch, Ethernet cable from switch to Net3 Gate, from Gate DMX out
Please help how to make it work right.
Adam
