I'm running v5.1 & have been having trouble recording some master playbacks into presets. The problem is intermittent & confirmed by two other users of my console. It first appeared prior to the upgrade to v5.1 while still running v5.0.
Most of my master playback content is groups & I generally use these for a basic build for presets. The general procedure is to raise the desired faders to the desired intensity & record. Sometimes the master playbacks record; sometimes some record while others do not; sometimes none record. The workaround has been to select the groups, set a level with the keypad or wheel & record, which explains why movers always record. Exclude master playbacks from recording in presets is not enabled in Settings.
ETC Tech Support suggested rebuilding the patch from scratch. That has been done & did not resolve the problem. They've examined a show file & could not re-create the problem. They suggested a next step might be to re-image the drive.
I would appreciate any other suggestions.
Regards,
Keith Ellison, Henry County Performing Arts Center, McDonough, GA
