Issues / Feature Requests
Hi .. we've owned a Congo since 05. I love this console, but as with all things leading edge occasionally there are hiccups. Let's use this post to report odd behaviours, work arounds, and feature requests to ETC and Congo development.
David Brenchley
Hope Community Church
Raleigh, NC
[edited by: Dave at 3:43 PM (GMT -6) on Wed, Nov 15 2006]
  • Ah, thanks Sarah! for some reason it simply hadn't occurred to me to, you know, use the proper keystrokes there. Um. Rats. [smacks self on head].
    I'm on v4.2.1 at the moment & also looking forward to the MacCongo beta.
    I could have sworn I've had live content pulled into the group editor before, but I do tend to bounce back and forth between Live and Group List while editing and it's highly likely I've actually put it there myself accidentally. I feel pretty confident about the rest of the list though.
    If it is helpful, I forwarded a show file of mine to your engineers recently for a crash issue. I wouldn't have thought to ask you to dig into it for what look to me like simple bugs, but if I'm the only one out there experiencing them, by all means, have at it! I really don't want to be special.
  • Hey Sarah and Team ... how bout ...
    The ability to "chase" sequences with all applicable times ...
    Recording presets via the bump buttons
  • Hi Dave!
    I'm not sure what you mean by "the ability to "chase" sequences with all applicable times"... Do you mean something different than using a regular sequence as a chase? Because you can already do that - either set the sequence mode to "Chase" from "Normal" in the Sequences list, or you can use wait times and the Link To Step function to create a looping sequence. If this is not what you want to do, could you provide more details?
    Also, you can record presets directly to masters by setting up the look you want, selecting the channels you want to include in the preset, and pressing RECORD & MASTER KEY or # RECORD & MASTERKEY...
    Hope this helps!
    Sarah
  • Sarah ... could you expound on "Link To Step function to create a looping sequence" ... it sounds like that exactly what I would like to do ..
    can this "looping" sequence then be applied to a master ??
  • Sure - in the sequence editor, scroll to the right to find the "Link to Step" column. Enter the number of the step you would like to link to in this cell. For example, if you want to have the sequence run continually without playing the blackout in between the last step and the first step, simply scroll to the last step in your sequence, then scroll over to the "Link to Step" cell and type 1 MODIFY. Then place the appropriate wait times on all the steps in the sequence so that they will "autofollow". This is essentially what setting the sequence to CHASE does, as well.
    Hope that helps -
    Sarah
  • Is there a way to simplify channel checking?  We currently are using the RRFU for channel check.  The problem is that it does not skip the channels not used in the show.  On our Obsession II we always put the RFU into the used in show flexichannel mode to facilitate easier channel checks (once the show is open).  Is there a way to do the same for the RRFU on the Congo?  Especially since there isn't a display on the remote yet.
  • Hi Mat -
    Congo can be set to a permanent "Flexichannel" state by using the channel NAME function in the Channel List. Normally, channels are always named 1-to-1 and unpatched channel numbers appear on screen. If you want to "remove" those unpatched channels permanently, rename them to 0. When renamed to 0, the channel no longer exists in the Live or any other channel displays. This way, Check + and Check - will skip unpatched channels.
    Hope that helps -
    Sarah
  • Thanks.  Although it would be great if there were a faster way to do this in some future release.
  • Hi to all,
    Here are a few requests for some new features we could hope on a new Congo version.
    Inhibit masters at any place in any master page (could be a new column to check on the master page tab)
    Rubberband on/off for ANY master (a new column as well).
    I think we definitely need those 2 new features... What do you think about it?
  • Actually, both these features are planned for an upcoming software release later this year.
  • Anders, I love you.
    thanks for making Congo better and better...
    Stephan
  • Apologies for reviving a dead thread, but it's preferable to starting a new one.
    Is there any way that in a future release the Congo Jr. Master Playback Wing can be run as a two-scene preset?
     I know there's a way to setup presets on the board using the software, but as somebody who does slightly complicated shows without using cues a few times every year, the ability to manipulate sliders is preferred to using a software interface.
    [edited by: Arel at 11:55 PM (GMT -6) on Sat, Jul 21 2007] spelling/grammar
  • Hi there -
    This is not currently on our list as you would be limited to 20 channels per scene. You can run the console in a single scene mode in Channels Only, or perhaps instead of thinking in two scene you could build a number of groups and play those on the Masters? Just a thought...
    How many channels would you want to see in a two scene mode?
    Thanks -
    Sarah
  • Not sure this is the proper place to post this but seemed the best fit. I've worked on some projects recently where it would have been great to have a standalone device with a bunch of sliders, programmable displays associated with each, and a USB interface to a computer. I searched and never found anything that fit. Then it hit me that this is exactly the Master Playback Wing for the Jr.! Is it possible to purchase these devices without owning a Congo Jr., and if so would ETC provide documentation on the interface programming? Or does ETC purchase these from another vendor who could sell them?
    Randy
