Just looking for some clarification on this. I believe right now, if you want the P/T of conventionals to come in from VW, you need to use Focus Points correct? And you need to have those focus points visible during the export process?
Is there ever a world in which the P/T info could come in just from entering raw data in the P/T fields in the lights without needing to make focus points? For some systems, mainly sidelight, it's easier to just tilt all the lights across the stage, and then tweak the focus in Augmented. To have to create a bunch of Focus points to just shoot light across the stage is a little tedious. Wasn't sure if this would be a valid feature request.
thanks
Cory
