Hazer
I have a hazer that I would like to configure to run at full for 10 seconds, then at 0 for ten seconds, cycling indefinitely. What is the best way to set this up? A cue on a sub? An effect? A chase?
I would like to make it so that there is no way to accidentally record the hazer level into my show cue list, too, and ideally I would like to lock the hazer sub/effect/cue/chase so that it won't accept changes made in the programmer accidentally.
  • I would suggest making an Absolute Effect with 2 actions -
    1st Action Time 0, Dwell 10, Level 100
    2nd Action Time 0 Dwell 10, Level 0
    Run this effect on your hazer and record that channel into a Sub. Make the Sub Priority Shielded (which by default becomes Exclusive too.
    Voila. Use the bump button to start and stop Haze. You can't override this sub from anywhere else, nor can you record it into a cue accidentally.
    [edited by: grahamparker at 4:15 AM (GMT -6) on Wed, Mar 27 2013]
  • You could set this up as an effect on a sub with locked presets.
    1. Record two presets:
    Preset 1: Hazer at full (or at it's "on" level)
    Preset 2: Hazer Off (or at it's "off" level)
    You can then Lock these presets to stop changes being made accidentally.
    2. Create an Absolute Effect
    Action 1 - TIme 0 - Dwell 10 - Preset 1
    Action 2 - Time 0 -Dwell 10 - Preset 2
    Duration/Cycle = Infinite
    3. Apply the Effect to a Sub
    Change the sub to a effect submaster via the {mode} key.
    In live record the effect to the sub via
    [Select Channels] [Effect] [x] [Enter]
    [Select Channels] [Record] [Sub] [x] [Enter]
    4. Make the Sub Exclusive and Shielded
    [Sub] [X] {Priority} [Enter]
    Page 279 - 290 of the new Eos Manual will give you some more useful bits about changing the mode and whether it is a proportional/intensity master. But the suggestion above should get you on the right tracks.
    [edited by: Sammy at 4:20 AM (GMT -6) on Wed, Mar 27 2013]
  • aww i thought i was gonna be the first to reply!
  • I use filters to keep my hazer from recording in to cues.
    as for cycling it on and off, can't you use a background macro to do the same thing?
