Macro Editor
I've got a couple of questions about the macro editor- I'm not trying to do anything in particular, more just experimenting to see what can be done on the console / see what I can persuade it to do...
1. Some key presses don't seem to register in the macro editor, either when learning live, or directly editing (E.g. More Softkeys). If I am recording a macro, I'd expect it to post what I'm pressing- when I press 'more softkeys' it shows up in the diagnostic screen as a key press (More_SoftKeys) so why is it not recognised? Similarly with the arrow keys, and I think a few others that I can't remember off the top of my head!
2. Similarly, if I record a macro to open/close the browser ( Displays, Displays), it shows up in the editor as 'Open_Browser', but then doesn't do anything (whichever mode I run it in) when it is run.
3. Following on a little from point 1, I know that it is possible to type into the macro editor when scroll lock is off, however the editor then seems to run typed in commands as individual letters. I.e. If I turn scroll lock off, edit a new macro to say 'Full', this is treated differently than if I were to edit a macro with scroll lock on and press 'F', which automatically turns into a 'Full'. Going back through it with the arrow keys, I can see that my 'proper' command is highlighted in one go, whilst my typed command is highlighted as individual letters. Is there a way to tell the console to treat it as a complete word by means of brackets or something?
Ian
  • Anyone?! Along the same lines as my previous question, is there a comprehensive list of supported UDP commands anywhere?
  • Hi there,
    1. Key presses that don't go to the command line typically are not captured. More SK, arrows, and the like are all not captured. EDIT: After further digging -- Some commands are very context sensitive (what screen is open, where something is highlighted, etc...). Currently, we don't capture these because of the required context.
    2. I'll need to check on this. EDIT: This command isn't supported yet, but it is planned to add support for it.
    3. This is the difference between a command recognized by the console, and a keyboard entry that will get turned into a command when played back. Categorically, you'll want to have commands in the macro editor unless you're doing things like labelling. There isn't a way to convert it - it's best to start with the needed commands and work from there. Sometimes, I'll learn a macro with all the commands I need, then go into the macro editor to clean any extraneous items up afterwards.
    UDP commands are the same as the serial commands, which can be found in the Eos Family Show Control User Guide that's posted on the product pages for the consoles. (Convenience link here: http://www.etcconnect.com/product.downloads.aspx?ID=22125)
    Hans
    [edited by: Hans.Hinrichsen at 1:52 PM (GMT -6) on Fri, Dec 20 2013]
  • Thanks for getting back to me Hans...I guess I was imagining that all commands would go through a central 'command processor' if you will, so the console should respond the same way to (for example) a '_Clear_Command' or 'Beam_Palette' (basically what you see as 'last command' when on the diagnostic screen), however it comes in, be that through the face panel, macro, UDP string etc etc.
    With regards to the link you posted, I have already found that documentation, and through my own trial and error, I know that there are more commands supported than listed- (_Clear_Command, Sneak, Block to name a few).
    Oddly, sending a
    <U1> $ Beam_Palette #, or <U1> $ Color_Palette # etc seems to default to posting:
    'Beam Palette 1' or Color Palette 1' etc to the command line. (If I put a number following the command, it will run that particular palette number).
    Basically, it all seems very inconsistent with regards to commands that are/are not/are a little bit supported, with very little documentation! I suppose what I'm looking for is something similar to what Strand produced for Genius Pro (manual extract attached) with relation to their MIDI messages and key codes! (see about halfway down the attached document) By using these reference codes, you are able to send pretty much any command the desk could respond to via the serial port.
    Ian
    [edited by: irw at 4:08 PM (GMT -6) on Fri, Dec 20 2013]
    page8.zip
    Commands are interpreted as the local user of the console and are processed by the same logic as a user pressed button.
    Every command is supported! If you can press the button or add it to a macro, then you can send it via UDP. It would be a very big manual if it listed every command.
    irw said:
    Oddly, sending a
    You are sending a CR (&h0D) after the command. This is the same as pressing [Beam Palette] [1] [Enter].
    To layer commands don't send a CR until your command line is finished.
    A little unfair, the document doesn't detail every single possible button press (but does say every button is possiable) as it would go out of date the moment a new version of software is released.
    Keycodes makes for a difficult for human to read command line, but does allow it tobe sent faster. Modern serial speeds mean we can send human readable commands with out experiencing lag. Again you can send and command via serial/UDP to the EOS. MSC is also fully implemented.
    The only difference between EOS and Genius Pro with CommuniquéPro is the fact that CommuniquéPro assigned every action to a midi note/sys ex command.
    On a cue stack based desk (like the EOS, and Strand 300/500) it seems folly to have every action pump out a midi command.
    On a "busking" based desk (like the Cobalt/Congo) it makes more sense.
  • Hi Marcus.
    Terribly sorry, I completely forgot about this thread until I've just started looking at my little project again!
    Thanks for the comment about sending the CR after the command- I've tried leaving this off and suddenly things are behaving as I would expect them to.
    I understand what you are saying about a list of supported commands going out of date with new software releases, but it would be nice to have something as a basis to work from, instead of doing everything by trial and error!
    Going back to the subject of the Macro Editor- when programming softkeys into the macro editor, it looks to me like when you scroll through the list you are seeing all the various 'pages' of softkeys, resulting in many, many duplicates- I'm sure I've seen somewhere on this forum (a while ago) that there were plans in the pipeline to tidy this up? It would be incredibly helpful if it could display commands in alphabetical order, for example!
    Ian
  • you'll get your wish for alphabetized softkeys in the macro editor in less than two weeks ;)
