Need help advising IT department on setting up a laptop of ION mirroring
So I spent way too long being very frustrated today...and ultimately defeated, trying to get a customer's laptop to work in mirror mode with ION.
I have pretty much concluded that it is somehow related to the firewall setting.  I know it is the laptop because I can connect with my laptop just fine.
The machine in question is running Win 7/enterprise in a university....very locked down.  It says the firewall is disabled...but it doesn’t act like it is...and I am not able to change it because of permissions.  It seems to always flag the network connection as PUBLIC...but doesn't let me modify it to anything else.
A clue is that NET2Config can not discover anything on the network...once again, my machine can find all the NET2 nodes and dimmers just fine.
I have tried reinstalling both NET2Config and Nomad as administrator (who know what that really means when it is so locked down).
I have been asked to send the schools IT department a detailed email explaining what needs to be done to make this work.  From what I gathered, the machine needs to allow the following through the firewall:
C:\Program Files (x86)\ETC\Eos\Eos.exe
C:\Program Files (x86)\ETC\VersionDetect\ETCVersionDetect.exe
C:\Windows\System32\hasplmp.exe
C:\Windows\SysWOW64\slpd.exe
Am I missing anything?  What other advice/info should I give the IT folks?
  • Hi Bruce ,
    sorry you are having difficulty getting the mirror mode connected.
    Could you answer these questions in the meantime until my colleagues get back to you with your answers:
    1.)What are the complete network details of both the Ion
    and Laptop? For example:
    Ion Ip Address: 10.101.100.101
    Subnet Mask: 255.255.0.0
    WindowsGateway IP: 10.101.1.1
    Laptop IP: 10.101.1.101
    2.) how are you physically connected to Laptop from Ion?
    A.) Cross over cable?
    B) Switch?
    3.) you say you cant see Nodes in Net2Config, but you can't see nodes from your laptop. from where can you see the nodes then?
    4.) can you ping the ip of ion from laptop? ping function is in Setup->Network Tab
    5.) what kind of switch is used between ion and laptop?
    a.) unmanaged = good
    b.) managed: what make/model? Some easy managed switches filter lighting data like ACN which is needed to
    sync mirror mode. sACN will continue to work to turn on/off lights, - just no sync.
    6.) What happens when you try to connect laptop with Ion? At Start Shell are you offered the Mirror/Mode Option?
  • >>1.)What are the complete network details of both the Ion
    from memory...so there might be some errors
    ION: 10.101.100.101 - 255.255.0.0 - 10.101.1.1
    Laptop (dhcp assigned by ION): 10.101.50.101 - 255.255.0.0 - 10.101.1.1
    My Laptop (dhcp assigned by ION): 10.101.50.102 - 255.255.0.0 - 10.101.1.1
    Laptop <-wired->5-port unmanaged switch
    ION<-wired-> to same switch
    same switch <-wired-> the rest of the lighting network (2 managed switches, 5 CEM+racks in two locations, Unison CMEi, a few NET2 2 port & 4 port nodes)
    none in system
    >>B) Switch?
    5 port linksys supplied with original Emphasis
    I CAN see nodes from MY MACHINE...but not the customer's machine
    I can ping from laptop to ION (<2ms no lossed packets) . I didn't try to ping the laptop from ION, though.
    see above
    The managed switches supplied by ETC in system a bunch of years ago. They are NOT between the laptop and ION.
    It offers mirror and I try to connect...but it can not find any masters. Once again, my machine is able to connect in mirror mode no problem, and both laptops are getting IP via DHCP from ION correctly.
  • When will you be on site again?
    1.) It would be good to get on the customer's laptop:
    Run->cmd->Ipconfig and see what the Network details there are. There maybe a problem if it has two Windows Gateways listed. You would need to get into the windows network settings, and delete the second windows gateway ip that is listed (in advanced settings)
    2.) Customer's Laptop -> Run->services.msc - make sure SLP
    is running!
    3.) Would be good to see if you can ping customer's laptop from Ion.
    4.) Both Eos Nomad on customer's laptop and Ion need to have the same exact Eos software version and language! What are the versions on both?
    5.) when you press MirrorMode on customer's Laptop - you get an info screen saying can't connect to Master - below that message you can click on Troubleshooting, and then on the following display in th right side of display should be Ion listed.
    is there a red X crossed over that Ion? If not you should be able to click it and it will connect.
    6.) You installesmd Nomad as Admin? did you also run nomad as admin? (right click icon , run as Admin)
    Good Luck!
  • Bruce - I'm sure Corey and the ETC team will resolve your issues, but noticed something interesting. The Ion is giving these laptops IP addresses in the 10.101.50.1xx range. If you have a device with a hard IP of 10.101.50.101 for instance and that device is not on the network with the ion when you boot up another device you'll have a conflict causing network issues. It turns out the suggested ip settings for DMX net3 gateways is 10.101.50.1xx. I point all this out to ask if you have other devices on this network and if one of them may be a gateway with a hard IP address of 10.101.50.101? If so, and the customer laptop is trying to use the same address....not good.
  • Hi Bruce,
    A few thoughts come to mind:
    I agree that it sounds like a firewall thing. Eos.exe is the main thing that needs to get through for console to console discovery.
    Second - Eos needs to be able to start the SLP service. If SLP is disabled or also blocked by the firewall, you won't be able to discover other consoles. Going to Run -> services.msc, look for Service Location Protocol and start it if it is set to stopped.
    Given the setup, I think you have communication from the laptop to Ion otherwise - just the bits of software that need to talk to the console aren't allowed through.
    Hans
  • Hello again all.
    SLP is running. The IPs ( the numbers I posted were from memory) are all good addresses...no conflicts. I can connect my laptop (also assigned an IP from ION) just fine.
    What I am looking for is what to tell the school's IT guy what needs to pass in/out of the machine. I can make sure what needs to run is running...but the IT guy seems to be the ONLY person who can change security setting on this machine. My gut feeling is that ETCVersionDetect requires less firewall access than ION...which leads me to believe it is firewall.
  • Make sure there's a Windows firewall rule to allow EOS.exe  for both UDP and TCP traffic on all ports.
