CopyTo Ignore Dark Moves
Is There/Can There be an option to copy a cue and if lights are at zero, their state is not copied over to the new cue but only their zero value?
  • Haven't tried it, but don't see any reason why you couldn't be in the source Cue and type:
    1 thru (insert highest channel number) Select Active CopyTo Cue x
     I appreciate this will not give zero values so will let stuff track into the cue, but if you created the new cue first and made it a Block with all channels at zero, then did the CopyTo command....
    Long winded I know, but some cunning macros would probably make it easier.
    I know where you are going with this, I have been trying to work out an easy solution for ages so any better suggestions would be welcomed!!
  • jabadger:
    When you say "lights" are you referring to MLs, Lights with scrollers, lights with NP's, that sort of thing?  If that is what you're referring to, here's a couple of ideas you could try:
    From live, bring the cue up on stage, then enter [intents {make manual} enter].  Then [record only cue # enter]
    or
     in blind, copy the cue to where you want it.  In your newly created cue enter [All NP's make null].  I've used that syntax before and essentially it makes those NP's track from the last instruction.
     Not 100% that this will work, but I'm quietly confident. Hope that helps
    Cheers
  • Yeah but I'm lazy and don't want to do all that, I'd rather just have it be an option that pops up on the softkeys. Plus, you have to be in the cue to do that, and half the time I'm copying cues that I'm not currently sitting in.
    [edited by: jabadger at 3:58 PM (GMT -6) on Sat, Jun 07 2008]
  • As a work around can you use SELECT ACTIVE, COPY TO, XX???
  • Yes, if you're in the cue, but even then it doesn't seem to work quite right. I was looking for something you could do without being in the cue. Plus this doesn't work if the cue before the one you are creating has an effect (intensity) running, the effect will track.
    [edited by: jabadger at 9:28 PM (GMT -6) on Sun, Jun 08 2008] [edited by: jabadger at 8:45 PM (GMT -6) on Sun, Jun 08 2008]
  • jabadger:
    Food for thought:  How about [select all intensity recall from cue n enter] ??  If you use it regularly, would a macro work?  Regarding effects, I think you would still have to manually remove them.
  • I agree. The workarounds are a lot of extra key strokes. I am commonly working in Cue Only mode (perhaps part of the problem but necessary for the skill level of the crew) and I commonly need to make blackout cues without pulling manual parameter or effect data into a dark cue (sometimes interfering with auto mark). I would like to be able to go to Blind and type something like [CUE] [5] [-] [COLOR] [COPY TO] [CUE] [19].
    I guess this is more of an update request.
