Loading a Cue with a Magic Sheet
I'm running Element with the latest software/firmware.
I am creating a magic sheet to call up commonly use groups, cues, and even subs.
I'm having an issue specifically with recalling cues...  You see, I'd like to create a button the only LOADS a specific cue, but does not fire it.  Then I will then be able to hit GO, either in the MS or on the console, and the cue will fire.
However, I cannot seem to figure out the command line syntax for the LOAD button.
In summary, I want a button on a MS to do the equivalent of loading a specific cue, but not firing it.
Thanks in advance for the help.
Brent
