Hi all,
I don't know if the issue I'm having now is with iOS 10 or EOS 2.4 but I can no longer connect with TouchOSC. Is anyone else having this problem? Is there a work-around?
Hi all,
Can you ping the console ip address from your tablet/phone?
Hi Benjamin,
I noticed in the OSC Settings in your Mobile device,
your Host IP is not the same as your console.
The Host IP needs to be the same as Console IP.
Please correct this.
That should get it working.
Further more, it would be best to set ETC's recommended
IP Addresses for your devices to help with Troubleshooting in the future.
The Network Address in your Mobile Device needs to be:
IP: 10.101.124.201
Subnet Mask: 255.255.0.0
Gateway IP: 10.101.1.1
The Network Address in your Console Needs to be:
IP: 10.101.100.101
You can see the whole list of Recommended IPs in this Support Article
http://www.etcconnect.com/Support/Articles/ETC-Network-IP-Addresses.aspx
Hi Brian,
The original poster had all sorts of incorrect settings, despite saying nothing had changed. There is no issue with iOS 10 and Eos/TouchOSC. The only issues will be if your settings are incorrect.
If you post your settings we should be able to help.
Cheers
Dan
Hi Brian,
This seems like a different case. Your settings look good to me. Can you ping the iPad from Eos? The IP addresses and masks look good.
Dan
Yeah everything can talk and it semi does. From the iPad in the OSC software I can see what is being typed on the console under the Cues section. I can see the desk time, What cue is active and pending. It's not populating the fader or group pages. It all stopped working when I updated to iOS 10 and the desk to 2.4.1. It also won't respond to anything typed on the iPad.
Ah ok, sorry I slightly misunderstood. As I say it's working fine for me, but there may be an issue in TouchOSC on certain models which the developer needs to fix. You could try contacting Hexler.
If you open diagnostics on Eos and enable incoming OSC you should see any buttons presses from TouchOSC. If you don't then it's TouchOSC that's at fault here.
Cheers
Dan
