Movers On Subs
Hi All
I have programmed some Robe LED beam 150 onto subs. The pan, tilt, zoom and colour.
The problem is you put the fader up and they move into position and when you pull the fader down they go to their "home" positions.
How do I stop them from moving whilst I am moving the fader.
I am using an ION with the latest software and fixture library and a 20x20 wing
Thanx
bAz
  • "how do I stop them from moving whilst I am moving the fader."
    Uhm, I'm sure I'm misunderstanding... Why do you program Pan Tilt into subs if you don't want moment?
  • Depending on what exactly you are trying to achieve but you probably want to set the faders to Intensity master (I-Master) on the fader config page.
    If you set it like that then as you start to move the fader up the light will position and then fader up the light and as you fade down it will not move.
    If set like that you can press one of the buttons on the fader to mark (so it moves to the position before you start sliding the fader)
  • Edit: Mike A answered while I was typing.  His is a better solution but I'll leave mine anyway.
    You need to use more subs and break up the parameters you are using onto different subs (as ueli suggests above).
    For example, you could put intensity only for the movers on one sub (no other parameters recorded (not "0", just blank), and put pan and tilt (without intensity) on another sub.  If you need several different locations you use a different sub for each position onstage (no intensity), using only the pan and tilt info (unless you also want the other focus, or beam, or colour info at these separate positions).
    You bring up a sub to move the movers, you bring up the intensity sub to have them come on.  As long as you don't lower the sub with the focus info (pan & tilt, etc.) recorded to it, the sub with intensity only will not cause the movers to move as you run the intensity level up and down.
  • Keeping in mind that you HAVE to configure your Fader as an Intensity Master or else the Marking functions will not work properly. I-Master Faders make the Bump button a Mark NP button, no need to set it as Mark NPs in settings.
    (You can configure a button of a proportional master fader to Mark you NPs, but it will fade out your NPs and there's no way to fix that.)
    Ultimately, there may be better ways to accomplish what you're trying to do. You really can't run intelligent fixtures like you would conventionals.
    If you have your movers permanently at Full (Not Parked), you can Inhibit their intensity in one sub, and also use Palettes or Presets to assign their Colour, Focus, & Beam.
    (Also, you can assign a Fader Button as a Macro... A Macro to assign NP values.) . . . if that's easier?
  • I think you are making it sound quite complicated for bAz
    All it sounded like he needed to do for the problem in his initial post was set the fader as an I-master and as I said in my post if you set it like that, then one of the buttons becomes the bump button.
    Its not unusual to want to use movers such that simply sliding up the fader positions the lamp and then brings up the intensity, particularly if your rig is not massive and you need to use the limited number of lights in a flexible way.
  • Probably.
    I had a similar problem and have been exploring all of my options.
    (None work & no one here had anything.)
  • H everybody
    Thanks for all the replies.
    It would appear there are other ways to do this so I will explore them.
    Once again Thank you all.
    Baz
