Several Questions
Hi all,
A few questions:
1) Is there a quick way to view, using Reference Marks, where a marked light is moving?  For example, at any point you can hold down the [TIME] button and view the discrete times recorded in the cue.  I'd like to be able to select a moving light that is in a marked state (says 'MK' in the intensity field) and have the console tell me what cue that channel is actually moving is.  (we've been using [Mark] - [Earliest])
 2) What does a '+' in the Mark column mean?  We're using Referenced Marks.
3) We're having a strange situation with [Sneak].  The best way to explain it is to give you an example: (all numbers changed to protect the innocent)
In live, we're sitting in cue 5.  channel 34 is tracked at 50%.  we then go to Blind of cue 5 and change channel 34 to 75%.  Then, back in Live we [Sneak] channel 34.
 On Obsession, the last [Sneak] command would move channel 34 to 75% over the sneak time.  On ION the level of channel 34 turns red but stays at 50%.  Why is that?  On ION, how would you get that channel to respond to it's new level?  Or, is it possible to selectively make an individual channel go to a cue? For instance:
Chan 34 [Go To Cue] 5 Enter
 Would that move channel 34 to the recently changed level? (without affecting the rest of the channels that have been modified)
 I know this is a kind of backwards way of approaching things, the question comes from my designer.  This is also a simplified example.
Thanks for your help!
Jason
 Programmer
'Streamers' Roundabout Theater Company
Jason Jeunnette
917/854-8211
eclairage@earthlink.net
www.eclairagedesign.com
  • Hi Jason.
    About Channel has a field called "marked in".  That will tell you the cue the channel NPS will actually be moving in.
    The + in the marks flag field means that a cue is both an "M" cue (is moving data not actually stored in it) and an "R" cue (has data stored in it that is actually moving someplace else).
    At this point, we don't update the playback buffer until the next go.  That's why you are seeing a difference in the behavior of sneak between Obsession and Eos.   You can [channel in question] [assert] [current cue] [enter].  Because assert has a default time, just like sneak, it will yield the same result.  Having said that, I think sneak with no destination should work the same way Obsession does.  So, that'll go on the list too!
  • On Obsession if you change the cue in blind, then go to live and press [ch] [sneak] it will not update to the blind level, it will update to the level it was at when in live.  To change to blind level you need to [ch] [sneak] [cue].  So the Ion is acting correctly.  Instead of [sneak] [cue] the command is now only assert, which may or may not be easier.
    Good luck, and happy opening.  Hope the set is fixed and water didn't screw too much up.
    Jay
  • Jay, thanks (yep, we found that too when we checked the Obsession behavior) :-)
    However, we think the idea of sneaking to the new blind data for the active cue is a great idea, even if Obsession didn't do it.   What do you all think?
  • I think that sounds like a great idea.  I don't really see any reason not to do that.  Thanks
    Jay
  • Which ever way the sneak function  above is changed... will the value of the sneaked channel stay manual (red) or be released into its updated state if it is being sneaked to a value already recorded in BLIND??
  • I believe that it will revert to the level of the current cue onstage (not the updated cue level) and no longer be manual (red).
    b
